Introduction
- Understanding Matomo
Matomo Core development
- Contributing to Matomo Core
- Contributing to Matomo Plugins
- Coding Standards
- Using GitHub Issues
- Pull Requests and Reviews
- The Core Team Workflow
- Maintaining Plugins
- Maintaining Translations
- Matomo APIs
- Debugging Core
- Profiling Code
- Reproducing Issues
- FAQs
- Core Components
- Composer dependencies
- Release Management
- Using GitHub Actions
- Matomo's Roadmap
- Matomo Plugin development
- Web Interface
- Utils
- Reporting API
- Data Model
- Tests
- Tools
Plugin Development
Reproducing Issues
Matomo core - Reproducing Issues
Test Example Scripts
We have a repository with various examples that let you easily test or reproduce a specific feature. For more information about this check out the repository.
Adding new examples
There aren't any restrictions on what examples to put in this repository. The idea is that whenever we need to test or reproduce something, we check if an example already exists and if not, then we think about whether it may be useful to add one to the above repository so others can reuse it in the future if we find ourselves building such a page anyway.
Regarding keeping them up to date: Since we mostly keep BC they shouldn't regress too much and if they do become outdated, that may be fine as we'd notice this when testing an example.
While we build new features or fix bugs (mostly tracking related) we build such pages often for ourselves anyway and the idea is to share these pages with the team so they can be reused in the future. There is no obligation to add such a page as part of building a feature although it would be great to do in some cases as it would be mostly needed anyway for the author of a new feature/bugfix as well as the tester.
Matomo System Report
If you can't reproduce an issue easily, then it may be useful to ask a user to provide the Matomo system report which will be anonymised automatically and it should be safe to share in a GitHub comment. Alternatively, this could be posted to us by email.
Testing data
As a developer it may be useful to generate test data. To do this, follow these steps:
- Install Matomo, for help see Setting up Matomo
- Install and activate the
VisitorGeneratorplugin via the Marketplace if needed - Generate websites
./console visitorgenerator:generate-websites --limit=50 - Generate users
./console visitorgenerator:generate-users --limit=50 - Generate goals for a website
./console visitorgenerator:generate-goals --idsite=1 - Generate visits for a website
./console visitorgenerator:generate-visits --idsite=1 - Trigger the archiving in case browser archiving is disabled
./console core:archive
